128 Segment Wooden Globe
I made this as a wedding gift for my brother, it took a long time as there were 16 double sided strips to machine and it was a nightmare to glue together. It didn’t turn out as well as I hoped due to seams/alignment issues but overall I’m reasonably happy with it. I think I have a much better way to do it if I ever try to make another one.
It is ~14" in diameter and made of Spanish Cedar.
The back of each strip was milled with a 1/4" ball end mill and the front a 2mm ball end mill.
I wrote some software to generate the g-code and in theory you could use this method to make a sphere of any size.
Here is one strip after milling the back side:
Here are all the pieces ready to be glued together:
There should be a “what can’t a shapeoko do” for this sort of things. Amazing project!
That is amazing! Interested in sharing your program for generating the sphere? What did you use for the front?
Unfortunately the software is a bit of a mess as I just wrote it quickly for this project, there are a bunch of hard-coded parameters specific to the stock I was using. I am planning on cleaning it up and including it as one of the templates in a CAM tool I am in the process writing.
As stated, the front was milled with a 2mm ball end mil.
I meant, what was the process for putting the map on the segments? Did you write software for that too, or did you use a program off the shelf?
Sorry, I didn’t realize your question was about the generation. The software I wrote creates both the back and front sides. The front is based on a heightmap, for this project I used the NASA ones from here: https://visibleearth.nasa.gov/view.php?id=73934
That’s really cool Shannon! You should consider entering it in the Community Challenge #17
