I took the existing GRBL PostProcessor and cleaned it up to make it better.
If you have a Makita RT0700 or Dewalt 611 or similar, it also translates the spindle speeds to a dial setting.
If you make mistakes in your design, the post-processor will alert you and recommmend how to solve them.
It’s free, documented, feedback & test-results are welcome.
Very interesting! I like the speed conversion for the router dial. Nice touch! I’ve just built my XXL and the dial setting was something I knew I had to figure out.
@Strooom I love Fusion 360, and would love a better post processor. I downloaded the cps file from GitHub and tried using it. I have nothing in the properties box in the lower right corner of the post processing dialog box.
Error: Failed to evaluate post configuration.
Code page changed to ‘1252 (ANSI - Latin I)’
Start time: Friday, September 23, 2016 3:34:32 PM
Error(C:\Users\sdcon\AppData\Local\Autodesk\webdeploy\production\8230b364be98230257f730ec9822611826c56dfb\Applications\CAM360\Data\Posts\OpenbuildsGRBL.cps:5): SyntaxError: missing = in XML attribute
Failed while processing global script.
Error: Syntax error: Missing end of literal at line 139.
What am I doing wrong? I just copied the cps file into the default configuration folder and tried to post from it.
It’s an error beyond my knowledge of Fusion.
I don’t understand the error message ‘missing = in XML’ as the .CPS file is no XML but JavaScript…
Let me test a few extra things and see if we can get someone from Autodesk to help us out.
Here are a few things you can try to troubleshoot :
download the .cps file again
after downloading the .cps file, open it in a texteditor (notepad or better) and verify the file is readible. Then verify it has V5 on line 16. This just to ensure you have the right file (I am a bit new to Github…)
save the .cps file into another location, eg. ‘my documents’ and then in the Post Dialog box, browse to this path for ‘configuration folder’.
Try the whole process with another .cps file (eg f360-easel.cps) to see if this makes any difference.
I am so happy with this custom post-processor, I want to make it work for you as well!
Ok, today I had some time to try and figure out what was going wrong. When I downloaded the .cps file from the GitHub page it didn’t have the V5 on line 16 like you said. So on a whim I clicked on the “Clone or Download” button and in the .zip file the correct file is in there. Comes up correctly in F360 now. THX!
Now I just need to finish my “Honey-do” lists so I can get back to my SO3XXL projects.
