Acrylic holder for the Carbide 3D Probe
Worked this up:
carbide3d_mount
Cut out of “6mm” (which in my case was actually 5.5mm) thick acrylic, e.g.,
Attaches to the front end plate — how you glue it together determines which side.
That is much nicer than the margarine container I was using. Hahaha
Your margarine container has a big advantage over my design — it accommodates the clip — I’ve been clipping mine to the SHCS for the belt anchor, but in retrospect, should have included a cutout (or a pair, a hole and a divot?) for the clip.
That was then, now I just unplug it and store it (in the same container) on top of the machine (out of the way)
Ref:
Resolved my oversight of handling the clip in the simplest way possible — just put a magnet on the endplate above the holder and put the clip on that.
Better photo of it installed / in use:
