Will be making alot of engraving on diff materials. For cockpit panels etc.
What is ppl using with their nomads for engrave? I have bought a 0.5mm and 1mm flat end mill and some engrave bits 0.1mm 15-90degrees to get me started.
I dont wanna sit in Fusions 360 and draw every letter in 3d like doing now. Has to be some smarter solution.
f-engrave. The real problem there is just a lack of fonts. That said, “drawing every letter” I don’t understand…Fusion has a text tool that works just fine, and takes 30 seconds to drop text wherever you want.
F-Engrave will use any OpenType or TrueType font which you make available to it — and if you can’t find one which suits your need, just make a custom one — I did that for the locking register calipers I made a while back:
I have yet to get regular opentype/truetype fonts working well. The only ones that seem to work for me (which is probably something I’m doing…not the tool) are the single stroke fonts.
