Book displays for my wife's 7-8th grade classroom
My wife teaches language arts to 7th and 8th graders. She asked for a book cart which morphed into a tabletop book display, one for each of her four classes, so a student could curate a bunch of books each week.
12mm baltic birch
Design in OnShape
Added chamfers as a post processing operation
Carbide Create files:
BookStandE-B.c2d (111.0 KB)
BookStandE-AD.c2d (580.3 KB)
BookStandE-C.c2d (139.7 KB)
Nice work! How does it transform into a book cart - sits on a trolley?
Also I’ve been doing similar work with ply etc and found a bolt style called demon bolts, also called Joint Connector Bolts. If you flipped the bolt around and machined a recess for the head it would give a flush and professional finish on the outside panel. Just a thought.
demon%20bolt
Love the hardware recommendation. I was just using what I had on hand due to impatience.
These don’t transform into a cart. I designed the cart and then decided to create a single shelf to test all the tolerances. She liked the shelf idea better so we evolved that design into what it is now.
Travis, my local electronics surplus store had these 10 per $ so I got a whole pile.![image|281x500]
(upload://qWdSLBMFcoAG7fEccurXfADbngU.jpeg)
Reworked the design and will post the revised files at some point. Just a bit more aestheticly pleasing and incorporating standard hardware.
