Brass, bronze and silver jewelry
(Camille Ouellette) #1
Hi there!
I am a former sustainability consultant and newly jewelry designer. I quitted my job in May to become a full time jeweler :smile:
I purchased a Nomad 883 this spring and I recently launched my first jewelry line using the Nomad. You can see below a picture of the final jewelry. For some unknown reason, I can only post one picture because I’m a new user :disappointed:. I use mostly brass, bronze and silver sheets, 0.8mm thick. The Nomad really allows me to replicate multiple and identical units of the patterns and shapes I have in mind. Before, I used to do all the cuts by hand, which was a nightmare!
If you’re interested, you can see the complete collection here: www.camillette.com/random
or follow me on IG: @camillette_jewelry
Jewellery details from the Nomad?
#2
Looks really great. Is it cost effect to cut silver vs a mold?
(Tina Aspiala) #3
Metalsmith here too–you can gather up the silver shavings each time and when you have enough, melt them down into something else, like another sheet of silver. :slight_smile:
(Camille Ouellette) #4
Thanks Chadw! I do the same as Spongefile, I keep the silver dust. There are also places that will buy precious metal scraps, like RioGrande. I haven’t done the math, but my feel is that when you reach a certain level of production, like producing hundreds of units, making a mold will probably be more cost effetive.
(Apollo Crowe) #5
Camillette - Very nice pieces, photos, and story, thank you for posting- beautiful!
And thanks for posting your instagram acct, you have a new follower!
ps: Congratulations on quitting your job! Glad the Nomad could help. :wink:
(Camille Ouellette) #6
Hi ApolloCrowe,
Thanks for the good works on my work, I appreciate it :slight_smile: I’ll try to post more pictures when I’ll have new pieces.
(Joseph Hinton) #7
When cutting brass or silver, do you need to use a coolant liquid? Do you use cutting oil at all?
(Camille Ouellette) #8
Hi Joseph,
Yes, I do use coolant. Especially for brass since it’s harder than silve. It extends the bit’s life.
(Renee) #9
Hi Camilette,
Your work is amazing, I’m a jeweler as well and just received my Nomad and want to make brass charms. Could you share what speed and feed you use? I will mostly be working with 20 and 22ga brass sheeting.
