Can we get 5' extrusions?
(William Adams) #22
FWIW, we ran a census back in the SO1/2 days:
https://www.shapeoko.com/forum/viewtopic.php?f=5&t=3938&start=10
and then an unofficial poll:
https://www.shapeoko.com/forum/viewtopic.php?f=11&t=5652&start=10
Interesting to go back and look at that now — 48" x 48" was the most popular option in the poll, and the second was 48" x 96" — but for the census, most folks had the stock 12" x 12" machine.
It’s also worth noting that there was at least some testing of a longer extrusion:
https://www.shapeoko.com/forum/viewtopic.php?f=7&t=5987
(William T Stokes) #23
All three links come up with the same error(at different addresses)
(William Adams) #24
Disqus rewrites URLs which contain certain characters — I’ve edited my post to insert them as hyperlinks.
(Stuart) #25
There are a few examples of guys joining the extrusions, with good results. This one is particularly tidy
Shapeoko forum: 54’x54’ scaled up shapeoko
(Phil Thien) #26
For 5’ extrusions I’d be willing to get an old pool table and use the slate top(s) (they come in one and three piece, I think) to use as a substrate for my base.
(Gene Gore) #27
I should receive my xxl upgrade kit tomorrow and will be joining my rails to get a 33x54 cut area. I will post pictures along the way and do a write up once I’m finished.
(Morten Dahl) #28
I have just made a cnc inspired by the Shapeoko 2/3 using Megarail80 which is very similar to the extrusions on the SO3. The router is 2000x1500mm and im experiencing a lot of vibration due to the large size.
. But the large working area I really great! :slight_smile:
(Anthony) #29
The endplates on an S03 are on the inside of the Y rails. I think supports could be bolted to the outside of the extrusions without interfering with any moving parts.
(Morten Dahl) #30
Yes I think you are right. That is also my next “upgrade”. I might need to cut of a little of the x-axis extrusion or else I would not be able to use the 40x40 extrusions at the ends. Due to a longer X-axis, when the wheels are on the inside of the Y-rail. It would probably also help to upgrade from 9mm GT2 to a 15mm wide GT2 belts
(Gene Gore) #31
A center support on those rails would help.
(Kyle Itzen) #32
I have been looking for a 4x8 machine and found the Routakit HD is available in 1500 x 2500 mm.
(William Adams) #33
For those who’re curious, that started on the Shapeoko forums: https://www.shapeoko.com/forum/viewtopic.php?f=11&t=3835
(Stuart) #34
I looked quite seriously at the routakit HD, but the cost of getting it sent to Australia was quite ridiculous.
I only want something wide enough to fit a 4’ wide sheet. It would really make it useful for small production runs!
I’m thinking I’ll join the SO3 & XXL gantry, make the base out of 1/2" steel or 3/4" aluminium with an HDPE wasteboard.
If the extrusions are relatively consistent in size I think I’ll get an aluminium block machined to fit between the two extrusions, maybe 6" long, then run some bolts through it.
