I cannot figure out why I am unable to center a .37" hole on a 2" x 2" nameplate. The hole wants to drill on the lower-left side of the plate even thought I have programmed everything to center. See picture and I have also attached the Carbide Create 3.07 file.
Any suggestions / thanks!
That’s such a weird bug, I assume it a programmed in low end cap? Aside from making sure the dimensions were >=0 I’m not sure why you’d impose a low end cap on stock size.
