Carbide Create Limitations?
(Chris Drewcock) #1
I am new to the CNC world and I am experimenting, but I have run into a snag with Carbide Create. I am trying to create tool paths for the image I created in AutoCad. It is below:!
Although this is just an image I have saved it as .dxf (without the colour) and tried to create tool paths that ultimately create three different depths. The white being the deepest cut, the orange next and the black being the top of the material. My problem is that when I import it into Carbide create it just seems to select what it wants to and also some of the lines are purple (Which I believe means there are incomplete or dangling lines) But I have gone through very diligently and cannot find anything. I am wondering if this is not something Carbide Create can do…
(Josh) #2
Should be doable? I’m not super well versed with Carbide Create yet, but having run into a snag with a few objects imported from .svg you may want to draw lines/objects yourself with the curved line tool in carbide create.
(William Adams) #3
That should be workable.
Things which you may need to do:
If you’d post the Carbide Create file here, or send it in to support@carbide3d.com we can work this up as a step-by-step tutorial.
(Chris Drewcock) #4
CAD11.c2d (1.1 MB)
Attached is the file. Thanks for the interest. I only have limited time to learn this.
(Stephen Gullage) #5
Great looking logo, I like how the C and D are one long curve. One issue you’re going to run in to with this image is going to be the sharp inside corners of your pockets, once you do get it into CC. The endmill, being round, can only give you round corners. This is the logo done at about 8.25" across, with a 1/8" endmill.
From the Z
From the side
The bigger you are going to cut it, the less it will be affected by the rounding of the corners. This is the same logo done at about 28x28
Here are the parts I used to make this, hopefully that will speed you on your way:
logo white.dxf (6.0 KB)
logo orange.dxf (6.0 KB)
logo black.dxf (196.7 KB)
(William Adams) #6
The problem is the file has been imported with open paths:
In order to fix this you will have to:
  • select all the paths which define an area and close them
  • if need be, duplicate and punch some paths out
In addition you’ll need to:
  • resize the Stock Size to match the desired output size
  • rescale things to match that size
(William Adams) #7
Begin by selecting contiguous paths:
then click on the “Join” icon to combine them into a single path, then go into edit mode and drag nodes on top of each other so that they will then allow joining and closing of the path:
Repeat this for other elements — using Boolean union as needed to combine things. When one arrives at a point where one has elements which need to be combined:
Edit them so that they properly overlap and can be unioned:
and as needed, duplicate elements and punch them out using Boolean union:
so that one doesn’t have intersecting toolpaths:
(William Adams) #8
Eventually you will arrive at:
(William Adams) #9
and after assigning toolpaths it will preview as:
CAD11_v2.c2d (2.0 MB)
(Scott Conant) #10
Also, the smaller the bit, the tighter your inside corners.
(Chris Drewcock) #11
Thanks for everyone’s help. I will be reviewing the steps, Will. Very helpful.
(system) #12
