I really like Carbide Create! It’s much quicker for simple operations than the CAD Program->STL->MeshCam process. However, I want the ability in Carbide Create to specify whether climb or conventional milling should be used for a toolpath. I’ve found that in certain types of plywood I need to use climb milling exclusively to ensure the wood fibers are actually cut…
Cheers,
David
