Hey guys. It would be awesome if we could specify a maximum flat depth when using V-Carve tool paths in Carbide Create. More like a combination of V-Carve and traditional milling. Maybe call it in-lay inside/outside? This would bridge a huge gap between Carbide Create and Vectric VCarve.
Pseudo code explaining what I mean…
If (DOC <= MaxDepth) then
//V-Carve as usual
else // if DOC is going to be deeper than the specified maximum depth
If (InsideInlay) then // If creating a negative image in the material
//Cut profile at max depth along inside of contour
else //If creating a positive image on the material
//Cut profile at max depth along outside of contour
