I work with thin sheet metal so there can be a disparity to where the zero is at the start of the job vs the center. The sheet metal is also held down by double sided tape so it can be difficult to zero it using the paper method as it can press the sheet metal down just a tad too much. During longer jobs, I would LOVE if I could pause the job to adjust Z-zero then start it back up. That way if I am not cutting enough I can adjust during the job or if it is cutting too deep I can adjust accordingly.
It’s a popular request but it will require a large change to the internals of Carbide Motion. I’d expect that we’ll add it at some point but it’s not on the immediate todo list because of the scope of the changes.
Yeah this feature request from 2017 would be awesome. I am in the middle of a 2 hour job and realized I would get a better result with the rest if I could change the z-axis about .1mm. But too late in the job to start over.
