I just found this. Sorry to be so late to the conversation. I am just getting going with my Nomad and ordered your edge finder. However, I can’t use it until I can get the spindle turning in jog mode. If I can’t use the edge finder I can’t use the machine! So I am dead in the water here. Any idea when you are going to add this functionality?
Also, is there a way you can smooth out the jogging? It seems that there is a pause/stutter when in rapid mode. If you could produce a smooth movement like when you use the power feed levers on a typical knee mill that would be awesome. Then you could face off a piece, move up and in the radius of the cutter, zero that axis, and have a good zero from that edge.
I just did a big (for me) epoxy job. It would have made my life WAY easier if I would have known the Volume of my pocket. Both for Regular Pocket cuts and Advanced V-Carve Cuts.
That feature is already there. Just click or touch the position and it will toggle between relative and machine positions. I use that little known feature fairly often.
