I kinda lost here - I have a jpg that I’d like to use as the basis of a vcarve.
How does one go from jpg to something that can be pulled into carbide create without tracing my face off?
Re-drawing is best, a second option is to use the auto-trace feature in a tool such as Inkscape. The community has a bit on that here: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
Opensource tracing: http://potrace.sourceforge.net/ — web interface: http://www.vectorization.org/
Webservice for tracing: JPG to SVG (Online & Free) — Convertio or http://online-convert.com/
Alternately use a CAM tool which directly processes images: Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable or Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
F-Engrave is the usual free suggestion:
Thanks Will - I knew it was kinda a derpy question when I was typing. In the end, I really just need to sit down with inkscape and figure out what I need to do.
First see if F-Engrave will work for what you want — it’s a very nice tool with a very straight-forward interface.
Hmm - should I see a jpeg option somewhere in the menu setting?
I can’t tell if I need to convert this or I set it up wrong.
It might be that F-Engrave doesn’t support JPEGs and you have resave the pixel image as a file format which it supports.
I was able to convert to svg, I can see it as a preview in the carbide create window, however, when I try to actually OPEN the file, I get a beach ball. File is attached - willing to try?
Huh - is the file visible somehow? I can’t see it…
