Changing $100/$101 values via CarbideMotion/MDI?
(Phil Thien) #1
When running CarbideMotion, there is an MDI menu which apparently allows you to send stuff to the gerbil card.
I need to make adjustments to $100/$101 to accommodate some belt stretch. I’m not going to mess with Z ($102) now because I don’t know if I can measure it accurately enough yet.
I want these settings to be static (that is, saved through a power-cycle).
Do I type: “$100=40.061” and then click the SEND button?
Or do I type: “/$100=40.061” and then click the SEND button?
I don’t understand the significance of the slash.
And when I’m done with that, do I just enter the next command ($101) in similar fashion?
Do I need to do anything else to save those settings to NVRAM or anything?
Any tips would be welcome.
(William Adams) #2
It should be
$100=40.061 then click SEND
The / should be used for commands which Carbide Motion wouldn’t normally accept — $100 isn’t in that category I believe
Yes, just do the second command thereafter. Such command settings are persistent, so they will be saved to the EEPROM.
