since the retract does not give clearance for changing tool-I click continue at tool change notice then hit pause z will rise to top I can then turn off spindle change tool and hit start again (turn spindle back on) I also use a little spacer block to set new tool as same height as old one
I’ve seen a lot of people say to just post each tool change as a different job. This has worked out very well for myself and doesn’t take too much time.
Correct, that is best practice:
If you can work up a way around the software and hardware limitations which make that advisable though, that’s excellent.
