My cutter suddenly stopped moving mid cut 13% left to cut. I manually had to stop and restart machine and CM. Now cutter is no longer responding to CM. What can I do to fix this?
Fixed, apparently I also needed to disconnect and reconnect USB connection.
We have a knowledgebase article on this: http://docs.carbide3d.com/article/56-can-t-connect-to-machine-or-jog
But very glad you got it fixed!
I had this issue a few times and fixed it by replacing the USB cable that came with the Shapeoko with a higher quality cable with built-in chokes and isolating the laptop and SO circuit board power sources to a different electrical circuit from the router. Never had a problem since.
@Qwkpony That fixed my problem once and for all too. I would only be able to run projects that took less than 15 minutes…now I can run all day with no problems.
