Combination of Poket cut Raised & V-Carve CNC op. Using only CC
(PWCNC-Rick) #1
Solid Press. Treated pine board
11 3/4” X 31”
Cutters
.063 - Square for windshields and Pilot
.200 depth
0.125 - for rear windows also .200 depth.
0.250 - for Aircraft pocket .300 depth
#301 .500 v bit 90 deg forvthe Text
Carving Liner for airplane wing, cowl, etc.
Depth .060
Very happy with the result!
Ps. In process of redoing internet in my shop , will post the CC filed as soon as I am able.
(Alan Nicholson) #2
Very nice…I hope one day I will do as well🙄
(mikep) #3
Ah… The V-Tailed Doctor Killer… :slight_smile:
(PWCNC-Rick) #4
That was a Typical media driven tag put on an incredibly well built machine!
I’ve owned mine now for 6 years, flown all over the country, in good and bad weather and me and my family are still here. Two previous owners, both doctors.:wink: owned ea. For about 20+ years and never had a hiccup …
Many many a persons teased Walter Beech that he over built his airplanes.
Which he did! But untrained stupid actions will always end in bad results.
Guess forks make people fat, so it’s a bad tool? We should ban them!!! Lol
BE35 is as solid as the wood I cut it out of…
:+1:
(mikep) #5
Just a gentle ribbing… :slight_smile:
(Emil Prusha) #6
I have an off line router and use Carbide Create for all my tool paths. I use a Mac, and CC works so easily on it. I now use CC for engraving of signs and circuit boards. All I have to do is save the .nc files to a thumb drive and plug it into my controller.
(PWCNC-Rick) #7
Awesome
I have a Plasma cutting table in the works and I’m curious if I can run it with CC
(mikep) #8
Should work if it’ll take gcode.
