I recently purchased 4mm compression bit to cut plywood cutouts. Can anyone help me out with rpm, feed rate and cut depths? I have looked at formulas until my eyes are crossed! Im a little lost!!!
I found that the company that makes the bits is usually happy to provide optimal feeds, speeds, etc. spec’s for whatever material you are using.
