I am trying to cut out a shape with 3 streight sides and a compound curve on the forth side carbide create traces the curve side fine and then puts a large loop on one of the corner side it will not cut correctly is this just me
Carbide Create is a bit tricky to draw in sometimes due to the limitations of its curve tool — if you could draw what you want, or put up a file and describe your difficulty we’ll gladly try to help.
Thank you, I redrew it in Inkscape and did not have the problem when I imported it to carbide create.
