Cutting to deep
Using Vcarve to create gcode to cut a pocket 1 inch deep by .25 wide by 1 inch long in stock that is 1.5 inches deep. Using a .25 inch millend. keeps plugging pass 1 inch and jamming the router into the stock. I did multiple pocket cuts earlier today that were .75 deep and they were perfect. What am I doing wrong??? Using Carbide motion to run gcode.
Usually this sort of difficulty is mechanical.
Always check the machine per the checklist: https://docs.carbide3d.com/general-faq/machine-operating-checklist/
and check:
If those things don’t pan out, let us know at support@carbide3d.com and we’ll do our best to help.
Perhaps you could attach your C2D and NC files for us to look at to see what you are doing wrong…
stool leg face 1.zip (12.0 KB)
Retract height seems to be a bit over an inch — do you have 1" of clear vertical travel from where you set the zero? (assuming it’s on the surface — the stock is 1" thick?)
NC Code looks correct. Maybe you set your Z at the bottom or the top of your part?
