I would like to be able to define the grid sizing or at least display what the sizing is.
In Carbide Create?
- Job Setup (gear icon)
- Units — set as desired
- Document Background | Edit
- Grid | Spacing — set as desired
- Ok
- Ok
OH ok I don’t use background images so I didn’t look there. How about just moving the grid options out to the main setup dialog?
If everything is a top-level entry, then there is no hierarchy.
This is one of the things which I miss from NeXTstep — one could explode an application’s menus in their entirety so that one could see all the possible options for an application at a single glance.
