Diablo v bit speed and feed
(Tony Dyer) #1
Can someone please tell me what feed and speed you’d recommend for the attached Diablo V Bit? I’m currently burning pine and poplar when trying to carve letters - only on the deep portions of the font and sharp turns though
. Thanks in advance!
(William Adams) #2
We do have some notes at: http://www.shapeoko.com/wiki/index.php/Endmills#V-bits
though usually the suggestion is to slow down due to a lack of chip clearance.
My suggestion would be to start with the settings for MDF since poplar is pretty soft in comparison to most other hardwoods:
Wood
MDF
1/4″ #201 or #202
7.62 cut depth
17000 R.P.M.
1 Dewalt dial seting
2.75 Makita dial setting
2032 feed rate mm/min.
762 plunge rate mm/min.
(Tony Dyer) #3
Wow… I was way off! Thanks for the prompt response.
