Diamond Drag Engraving Granite First Project
Cool, book marked it for future, thanks Kenton.
I want to try an engraving bit like these, but theyā€™re all classified as ā€œdragā€ bitsā€¦ would you not want the router spinning, and if so what speed?
I think these are ā€œscratchingā€ bits hence the drag name. A burr should be spinning but the drag bits are spring loaded to control the cutting (scratching) force (down pressure) and spinning it in the spindle (imo) would likely break the spring. Iā€™m looking for the proper diamond burr bits for this process and if I find them Iā€™ll advise.
Hereā€™s a drag bit I just found on ebay, donā€™t know the seller and have not purchased from him ,
http://www.ebay.com/itm/CNC-DRAG-ENGRAVING-TOOL-BIT-SPRING-LOADED-DIAMOND-SHERLINE-TAIG-MILL-TORMACH-BF2-/192237140867?_trksid=p2349526.m2548.l4275
Also saw ā€œdrillmanā€ on ebay has router 1/4" shanked diamond burr bits, with so many referring Drillman, I will buy from him when Iā€™m ready.
Indeed I get the process, but Iā€™m asking about spinning the bit vs. not. Thereā€™s potential for things to bind or grind if the bit doesnā€™t turn but everything else is rotating.
Iā€™m looking for anecdotal experiences
No experience, but the link @GeerGuy posted had spring loaded ball mills that you use while spinning. Used for uneven surfaces.
Cut time was < 30 minutes.
Stepover .0050, 70" feed, .0001" stock to leave on a roughing pass only. Used a spring type diamond engraver.
Will center it better next time :slight_smile:
Hereā€™s the tool: http://benchtopprecision.com/diamond-drag-engraving-tool/ (Same one @geerguy) posted.
You do not spin this type.
Thanks your video prompted me to purchase drag bit and my first engraving on granite tile was also a Texas seal, very happy with the resultā€¦
TX_sgt I see that you are located in Texas and you use vcarve. If you dont mind could you tell me where you got your diamond drag bit.
First diamond drag engraver piece I did. Going to change a few things but happy with it.
Is this doable in CC? Or any of the other free tools? I might be able to spring $70 for the bit, but $350 is way more than I can do atm.
I have done it in CC.
It makes CC run really slow because of the tight tool paths, but it can be done.
Dan
Inkscape. Fusion360.
Thx guys! Yā€™all are the best :wink:
great work
Is that water you are using for the cutting fluid??
Great work. Iā€™ve got a blank piece waiting for time and musing!
Would you mind sharing your feeds, stepover, etc?
I got mine from Widgetworks.
Yes, and the water is only used to keep the dust down, and cool the diamond. The speeds probably arenā€™t
fast enough to generate much heat, but the water also adds a bit of lubricity.
TX_SGT What size was your Texas Seal?
