This has been brought up before (ie, Go to specific location using Carbide Motion? ) but I’d really like to see a way to input specific job coordinates. I’m working on something where I’m doing a bunch of work from the same zero position, but it will be batch work over a few weeks and I may in between want to do other jobs and lose my zero.
It’s easy enough to home, jog to zero, and jot down the coordinates but then returning to them requires finicky jogging. I know I can use MDI to send a move command but, really? I tried doing some trickery like telling CM that it was actually at say +300X when I wanted it to go to -300X, then telling it to go to zero hoping it would move -300 but no go, maybe I’m just tired and not seeing why that wouldn’t work.
On a related note how reliable are people finding this. Doing it by jogging back to the coordinated I’d used originally definitely left the second cut slightly off from the first. I didn’t notice the same issue when I did the jobs back to back, with the machine re-homing but then returning to the already set zero. Maybe I got lucky.
Kinda wish I could click an arbitrary spot on the rapid position tool also.
