Engineering drawings in Carbide Create
Every so often we get questions on how to go about this in Carbide Create — here’s a recent request:
rough_drawing
In Carbide Create start by making a stock size suited to the part, setting the zero to the center (useful as a visual indication) and the grid size to a number which matches the dimensions:
Draw in a series of circles centered on the stock which match the diameters which will be needed:
Then begin drawing in the circles, centered on the appropriate points:
Some circles will need to be rotated around the center so as to bring them into position:
Thus:
Repeat that for each circle, rotating it into the appropriate position.
Worked up a similar design on the wiki:
https://wiki.shapeoko.com/index.php/Carbide_Create_Basics#Engineering_drawing_example_with_rounded_corners
