Error (1) error in line 20: arc endpoint error?
(William Adams) #21
Ouch. I would worry about reflashing so much and wearing down the EEPROM — please try to minimize doing that sort of switching.
(Alex) #22
i wasn’t aware that i’m updating the eeprom when switching between two versions of CM4 … anyway , i’m not sure I have other option until the issue gets fixed (short of stop using the probe).
cheers, Alex
(William Adams) #23
Sorry, not sure why I read that as updating Grbl — switching copies of CM should be fine — maybe duplicate the directory so that you can switch by just re-naming the binaries or something?
You have to run the Carbide Updater or save a persistent setting to touch the EEPROM, so my concern on that basis was wrong.
(Alex) #24
that’s what i though :slight_smile: … and that’s what I did (change folder names).
cheers, Alex
(Luke) #25
@nicualex can you have both open and connected at the same time?
(Alex) #26
nope … at least on my setup (W10) they don’t work concurrently .
(Luke) #27
Thought as much. Hopefully a new version soon.
(Luke) #28
v 4.10 didn’t fix it :frowning:
(Griff Carpenter) #29
I seem to be having all sorts of problems lately😡. Now this pops up right after I update to 410 to resolve the probe issue. Just cutting a square to check accuracy of machine now that it’s back together.
Never saw this error on 409.
(Luke) #30
What, you too are having the end point error?
(Griff Carpenter) #31
Yep, bad week for me. Think I’ll go do something else for a while!
(Griff Carpenter) #32
Reverted to 409, error went away…
(Luke) #33
I will try that - I’ve gone all the way back to v4 and the last one that works for me is 4.07
(Scott Conant) #34
Which post processor are y’all using on F360? I have found that can make a world of difference with these arc errors.
Could give this a try:
@RichCournoyer had one written too, but I don’t have a lot of time atm to look for the link
(Luke) #35
I’m using Carbide3d.cps I have no idea if this is an out dated one?
(Griff Carpenter) #36
Thanks. Didn’t even know there were alternatives.
(Griff Carpenter) #37
Scott, problem solved. I think. I’ve only run one job in CM 4.410 but no errors.
COOL, thanks again!
(Luke) #38
How did you install the post processor?
(Griff Carpenter) #39
Here’s the link I found. https://knowledge.autodesk.com/support/hsm/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-add-a-Post-Processor-to-your-Personal-Posts-in-Fusion-360.html
(Luke) #40
Legend. That was much better than the article I found and could not follow
