3/4" MDF at (from center) 1", 2", 4", 8". 36" T-tracks from OrangeAluminum.com. Countersunk the screws in the middle. Thoughts/suggestions?
One question I have is I purchased (2) Rockler Auto-Lock T-Track Clamps (side clamps) but the track size is smaller than the T-bolt. I’m assuming I can either grind down the T-bolts or purchase replacements that are the correct size for the tracks and added distance with the 3/4" MDF wasteboard?
Do you have a spare bit of T track? If so, take it in to a hardware store along w/ a clamp — they should be able to set you up w/ suitable bolts (a simple hex head should work). If you don’t have any T-track to spare, make a rubbing of the end.
