I have done a bunch of test cuts and measured and followed the instructions in the Doc section I have the Adjustment #s for the X and Y Axis’ and want to adjust the steps. What and where do I make those adjustments in Carbide motion?? Hope you guys dont gonna get tired of all my questions!! Thanks!!
Go into the MDI and send the settings from there.
So for the X I would type $100=39.8509512 click send
Then for the Y $101=39.8605057 click send??
Then How do I know if the settings were aceepted?
Open a log screen (info from the setting screen)
Go back to MDI, and type $$ (Send)
Go mack to the log file (I recommend that you click STOP) scrool down to look at the $100, (etc) settings)
Thank you all for the help it worked!! Settings adjusted!! Tomorrow will cut some steps and then I will adjust that axis as well!!
