First Diamond Drag Project - Acrylic Commemorative Poker Chips
(Adam Albert) #1
I started a neighborhood monthly poker night several years ago, and surprisingly, the group has been going strong ever since. I just got a diamond drag bit, and I decided to make commemorative poker chips for the guys. The key here, for me, was to make them the same size as real poker chips. I am very impressed with the amount of detail I was able to get with this diamond bit.
Here is a run of 6 poker chips on 1/8" blue acrylic:
A quick profile with a O-flute plastic cutting bit (I love this bit):
And the final results when compared to real poker chips:
(Idan) #2
It’s hard to tell if the apparent lack of detail is due to the camera or that’s just what dragging can achieve. How good does it come out?
(Adam Albert) #3
I think that the dragging bit itself is able to achieve a significant amount of detail. The issue I think you are referring to deals with the way that I chose to use it. Here is a close up of one chip:
The diamond itself makes a fine line, but I didn’t just want an outline of the letters, poker hand, etc., so I chose to use a cross-hatch fill method. I only did the fill method, as I didn’t think to do a second pass to trace on each vector line; that probably would have made each letter stand out more. The good thing is that the eye is much more forgiving than the camera, and when the chip is held at least a foot away, the overall design and lettering come through just fine.
