I am using Motion v.3 at the moment. Just curious what is out there which would allow pausing of the job from a remote room by using a wifi network? I saw Octoprint CNC on the wiki but the link is dead and it seems they might just make software to run a 3D printer now. That had some really interesting abilities though of webcam monitoring and remote control from another room.
I can’t always be sitting next to the machine for hours on end. Right now I monitor the machine over my wifi network and an old iPhone as a webcam. Would be great if there is a way to have limited ability to at least pause a job from running if something happens. Nothing crazy technical ( i.e. If I have to know something above and beyond loading a piece of software that will allow this to happen, I’m probably not going to use it ). Is there a solution out there which is plug and play friendly or is this all stuff you have to hack on your own?
Mike, CM4 has this function built into it? I must have missed that when I was looking at the description of CM4 on the Carbide website. That is pretty much exactly what I am looking for. While I like the interfaces of some of the other gCode controllers better than what CM4 has, I would like to stay with what Carbide provides direct support for.
Yes, it’s built into CM4. It doesn’t show up in any of the documentation or anything, I found it by accident. Works really nicely though. Does require that you be running GRBL 1.1
UGS has a “pendant” mode that will do the same thing.
It’s actually an intrinsic part of CM4’s architecture — it just runs, and I believe it’s a separate process from the front-end / GUI which actually is a series of HTML pages connecting to it.
I have all of my 3d printers and Shapeokos on wifi outlets so I can turn them off at anytime from anywhere. I also have wifi security cams on them so I can view them as well. As I am in and out of the house a lot, it helps that I can quickly glance at the progress and shut everything down if need be.
