After countless hours of research I purchased a new XXL. In anticipation for its delivery I am messing around with Easel as their network of “projects” is pretty vast. Has anyone successfully taken a project from easel, downloaded the zip file with the svg code, and edited it in Carbide Create prior to sending it to carbide motion?
I know that you can export the gcode directly but I would much rather see whats going to happen first. For example when I download the zip and open it in carbide create Im noticing that several horizontal lines are missing. Thats kind of a big deal and dont want to waste product by just sending a bad gcode to motion.
The gcode from Easel will work without a problem…use the preview there, it’s accurate. You’re adding some steps and losing something with the export/import (I’m guessing open paths). I don’t know why anyone would use a sender without a visual preview of the toolpaths.
Yea after doing a bit more research I’m starting to find that several people were having issues with the open paths.
In your experiences have you noticed any issues with the settings? For example I’ve read about issues with the z-axis being out of wack. Thanks @neilferreri
