I am curious if and what the method is to remove the pixel border that is not part of an image. I think I tried leaving this area white and transparent… Is it possible when converting a grayscale image to STL file ?
Example- this is rough and only meant as an example :
Source image fed into embossify.com
I want those white bits at the top and bottom to not be part of the model when imported as a component into VCarve but what happens is the overall pixel size of the file has a border carved around it as though it is surrounded with a black border.
You can see it here after it’s been imported to VCP
I tried using MESHCAM to import grayscale images with the same problem. Whatever the overall pixel size of the image file is becomes part of the model and I can’t seem to get rid it it. With MC is was a little different and it instead floored the area that was set to transparent.
I used to be able to make this work with the Carvewright Designer software so I think there has to be a way to make this work but I haven’t figured it out yet with Vcarve.
