I am running the sparkfun version and had to use xloader to update the grbl firmware but after that everything seems to be working fine. Will add more information on how a couple projects I will be running go over the weekend.
I just updated to 1.1 and C4 (406). new GUI looks good, but I am still seeing this problem where the newly loaded file does not update. I tried loading a bunch of different files just to see if the boundary extents or file name would update, and after loading several different files it changed to the second file I tried from the first, but definitely did not update in real time.
a request. when using the MDI function it would be nice if you could hit enter to send the command, rather than having to mouse over to send. Also, it would be very nice if it showed the history of commands sent. just a 10-20 line scrolling log so that you get a visual confirmation that your command sent and what the last one was.
Iâm still seeing it too as of 4.06 update. Windows 10. Loading and reloading several times does finally show correct file, but this could be disastrous if I were to run the wrong file by accident.
Also have noticed that Iâm having issues with jogging via keyboard shortcuts, using mouse clicks works fine. X/Y work fine. Z does not work at all and jogging increments can no longer be set with Num lock + 1-5. Reported to Beta@carbide email, have not received response.(figure with new software release everyone is swamped). Mentioned in thread about jogging with wireless 10 key, but have not seen if anyone has the same issue(I could be doing something wrong?).
Thanks,
Dan
I have not seen this with 406 on Windowâs 8.1, but I did see it with the earlier versions. Please go to the RUN screen after trying to load the file (just once), and I think you will see that the file is in deed loaded, but the FILE page just isnât updating. Please let me know if this is whatâs going on.
Thanks
R
I have an IOT remote switch set up for the router on my SO3XL. The Gcode for the tool change is before the M3 to turn on the spindle, but when running carbide motion, the tool change dialog comes up -after- the spindle has been turned on. Which is not so helpful. Gcode was generated from carbide create in this case. Spindle enable/disable works properly (ie. on when M3, off when M5)
Gcode:
M6 T12
M3 S7639
G0âŚ
The remote control of CM is fantastic via the web browser! I use a Kangaroo PC at my SO3, and always run it headless. This is a lot nicer than needing to use VNC/RDP. This is an awesome feature.
I keep getting caught out by how the buttons work. The menu in the top right doesnât seem to work if another screen is up. Example: enter Jog, then ârapidâ, then click âjogâ or ârunâ in the menu - nothing happens. You have to click done in the page, then the menu works. Itâs totally unclear that the menu is disabled in these modalsâŚyou have to just know that you need to click the yellow âdoneâ buttons to get things working.
@SWBennett Have you resolved your issue with the âdoor openâ message?. I just upgraded to the new firmware and CM and are experiencing the same issues as you did. Sent a message to Carbide 3D already but was wondering if you already had their resolution to your problem. Could you share if you do, please?.
So I investigated further. (for ref running windows 7) It does as you suggested. When on the load page the file name does not refresh, but if you click over to the run tab it shows the latest loaded file. then when you click back to the load page it shows the new file as well. so i suppose the glitch is only in the instantaneous refresh of the load page.
what is the appropriate place for feature requests? I imagine you donât want the bug email filled with "i wish it had"s. Iâll assume this is the right place until Iâm told otherwise.
So I wish the MDI screen had a stop and reset button. If you give it a command and fat finger a feed rate there is, as far as i can tell, no way to abort. For instance G01X100Y200F10. is going to take FOREVER to get there. but if there was a pause/cancel/reset back to idol button you could back out and resend with a reasonable feed rate.
On another note, I guess the memory banks have gotten a lot better? I powered off my machine for the night and when I turned it back on i was able to go to the âzeroâ that I was using yesterday. Pretty handy really. My machine is still prone to random disconnects as it is a V2.2 PCB. so a quick home and return to zero to pick up a program or do a tool change is pretty awesome.
Hi
Jorge spent some time skyping with me to figure it out.
There was an issue with a pullup on the version of the board I have. I will have to defer to Carbide support to work out if this is the right fix for you.
If I where you and needed to use the machine, I would revert to the older versions for now. There are instructions above.
Thank you @SWBennett. I have already written them and are just waiting for their answer. Iâm on a Mac and canât figure out how to re-flash GRBL 0.9 again. Is it through Arduino?. The steps above say to use XLoader which seems to be a PC program. Am I missing something?.
To reflash on a Mac best to use the Arduino dev tools per https://github.com/grbl/grbl/wiki/Flashing-Grbl-to-an-Arduino
Thank you @WillAdams. Got 0.9 reflashed with HexUploader on my Mac and defaults were reset. Back to working order. Will wait until the official method for GRBL 1.1 for the Nomad Classic gets posted. Thank you all.
Seems to work great for me running the Hello World file - and now this version prevents my x-axis from crashing into the left endplate nicely.
One note - The instructions mentioned enabling homing, but that was not an option for me. I assume youâve changed this as all machines must have homing to function now.
I like having the feed rate changes (10%-200%) directly from the run screen. I agree that if you cannot use the upper buttons when in a settings dialog, they should be faded to the background to indicate you must press done when jogging, etc. I assume the spindle control is just for Nomads at this pointâŚ
I would love to test âcarbide connectâ and its headless capability as we would use it frequently instead of hooking a tablet up directly - Curious what happens if multiple PCâs try to connect at once. Also hopeful (pleading?) that the touch probe is released soon!
Iâm looking forward to cutting with it!
If you have a control set up for the spindle on a shapeoko, the spindle control does work as expected. Tool change doesnât work quite right, but the spindle control from the jog screen does.
Iâm using this one, and itâs working great so far:
To use it, you have to add a couple wires from the control board to the little green port on the side of the relay box, but itâs really, really, easy.
With the new GRBL1.1 and Carbite motion 4 Can I use triquetra?
I send a email with some problems I had on Friday but did not get an answer. Thanks
I see that Carbide Motion 407 was released several hours ago.
Link:
Iâm having the same issues with Jogging. X and Y work fine via the keyboard but the Z and increment controls are not working. Tried it out on a couple of keyboards still no luck. Resorted to using âReal VNCâ so I could remote into my computer and jog via my phone/tablet⌠not a great solution but it works for now.
I just used carbide updater and downloaded the latest version of carbide motion. Everything went well (better than I expected) and I have not had any issues. I use Vectric and all works well so far with the Vectric postprocessor,
