GRBL 1.1 update for SO3 Sparkfun Edition?
(Reiner) #1
Hi all,
I own a Shapeoko 3 Sparkfun Edition. Is it possible to update that one also to GRBL 1.1? If so, can one of you point me to documentation on how to do it?
Reiner
(William Adams) #2
I believe this will be the same as doing a Carbide 3D board — there’s explicit mention of entering a Sparkfun code at:
(fredmud) #3
Finally got around to updating my Sparkfun SO3 to GRBL1.1, and am posting here so that others might avoid the issues I encountered.
The Carbide Upgrader does not work, as it will not recognize the Stepoko (Sparkfun Arduino board).
I found great, detailed instructions to updating GRBL via the Arduino IDE at:
Sparkfun Shapeoko 3 Activation with v3 or v4
(Richard Fortune) #4
Appreciate you taking the time to share this. Super useful!
(James Stubbs) #5
I also have a Sparkfun edition. Do I have to fit homing switches first?
I would try the Arduino update.
Best wishes
(William Adams) #6
If you wish to use Carbide Motion 4, you’ll need to have homing switches.
If you’re using some third-party G-Code sender, not necessarily.
You really should get them, they’re a huge improvement/convenience
(James Stubbs) #7
Thank you. I will look into switches.
Using the IDE what board do I select? UNO??
Best wishes.
(William Adams) #8
Please see: GRBL 1.1 and Carbide Motion 4 and the following post and https://www.shapeoko.com/wiki/index.php/Grbl#Downloading
(James Stubbs) #9
Thank you for trying to help. But I am getting a little confused.
Do I upgrade using
Hex loader + Hex file
Or
Arduino IDE + Source file target board uno.
Best wishes.
(William Adams) #10
Whichever you prefer. They’re all valid.
(James Stubbs) #11
Just wanted to say Thank you William.
All sorted.
For anyone else that needs help.
I am using a macbook.
***Make sure you copy your existing GRBL settings ($$) somewhere as they will need re-entering after you upgrade.
I used these instructions https://github.com/paulkaplan/HexUploader/wiki/Using-HexUploader
Download the app from here http://paulkaplan.me/HexUploader/
Download the 1.1 GRBL hex file from here https://github.com/gnea/grbl/releases
Make sure you have the latest version of Arduino from here https://www.arduino.cc/en/Main/Software
When unzipped and installed - Make sure you copy the program to your Applications folder.
Run Hex uploader.
When completed. manually update your GRBL settings from the settings you saved at the beginning.
Best wishes.
