Max characters per line exceeded. Line was not processed and executed.
I’m stuck. After getting this message on the detail job for a 3d project I received this just as the job started. I went back and recreated the Gcode using Carve Pro v9. Same thing happened again.
Any help is appreciated. I’m stuck and need to finish this job asap.
I’m using the Shapeoko (inch) post processor out of Vcarve Pro v9.509. I pulled it up in Notepad but I’m not experienced enough to know what it should look like.
It’s a 12mb file and I’ve only posted to Vectrics large file email just now.
What line does the error occur at? I’d also check that the USB cables aren’t being disturbed (put weights on them at either end and don’t move your computer), and verify that EMI isn’t a problem.
Vectric has included a “post-processor” for the Shapeoko (a pair of them actually, one for Imperial measure, one for metric) since v8.5 — please let us know if you have any difficulties accessing them. Their “install” procedure is to move the one you want to move into a specific directory and then that one will be used and the others ignored:
I basically just created the Shapeoko (mm) gcode. this worked…I’m not sure what the issue is but I’ll stick to the output from now on. Thanks to all who helped. Will Adams, you are the man!
