GRBL Error using meshcam
(Duane Ballard) #1
I keep trying to run a job on my Nomad. About ten minutes into it I get “GRBL Error Serial Port UnknownError”. It did it twice and I went back into mechcam and redid the CAM file. Tried it again and the same thing. It doesn’t happen in the exact same spot each time.
(mikep) #2
The problem isn’t the CAM file, it’s more likely a USB error. Suggest you contact Carbide3D support though, this isn’t very common with the Nomad (much more common with the SO, which uses the same controller)
(Alex) #3
I had this problem with me SO3XXL about a week ago. I had the USB plugged in to a port on top of the computer and all I did was move it to a better USB port on the back of the computer. Hope this helps.
(system) #4
