GRBL Panel Training (Video)
(Adam X) #1
As promised, here’s a video on running GRBL-Panel with a Shapeoko 3 XXL (or any S3, really).
It’s quite long winded, I do love the sound of my own voice: https://youtu.be/kGbxkIHce9U
grbl panel can be downloaded here: https://github.com/gerritv/Grbl-Panel/releases/tag/V1.0.9.15
It’s quite a rough take with quite a bit assumed and glossed over, let me know if you’ve got questions. I hope this helps somebody!
Grbl Panel HowTo Poll
#2
Well done, Adam. It’s such a nice program. Perhaps more will start using it.
(Griff Carpenter) #3
Thank you, sir. You’ve opened a door for me, will be digging deeper.
(ted brantley) #4
I’ve been wanting to try GRBL Panel for a while now. Thanks for the helpful video. I just downloaded the software. :slight_smile:
(Griff Carpenter) #5
Adam, should I use a different post in F360 for grbl panel? I’ve tried a few files that worked fine in CM but cause red spindle errors in Panel. My spindle is manually controlled.
(Adam X) #6
I’m rusty on F360… what post processors are listed there? Is there a generic grbl post?
What lines/errors are you seeing? Toss up a screen shot… and post the gcode, I’ll take a look.
(Griff Carpenter) #7
Hmmm, I’ll have to send the gcode from my computer.
(Adam X) #8
Gah, that’s a really angry application error. Just to be sure it’s the app and not gcode, try running an airjob on the attached file (it’s a small 6x5" dust boot)Dust_Boot_v4.nc (149.4 KB)
(Griff Carpenter) #9
Hmmm, works fine. Should I try another post I guess?
(Adam X) #10
Attach the gcode that’s crashing grbl panel, now I really want to try it :slight_smile:
(Griff Carpenter) #11
Is this what the end screen should look like. I’m guessing not.
(Griff Carpenter) #12
heres the file
tray 4 cutout.nc (22.6 KB)
(Adam X) #13
WHOA, yea, crashed my panel too. I just did a debug and it looks like a bug in grbl-panel not wanting to accept tool changes with three digit numbers! Try switching your tool number in F360 to a two digit value. I just updated your gcode with it and tested and it runs now.
Attached for you to try…tray 4 cutout.nc (22.6 KB)
(Adam X) #14
New release of this software this afternoon, several big improvements:
@Griff I raised your problem as a bug to the dev and it’s been addressed in today’s release
(Griff Carpenter) #15
Sweet, thanks. I’ve renumbered all my tools, ha ha. I was fighting through a fusion reinstall yesterday, very frustrating.
All’s good now. I’ll try out the update.
(Adam X) #16
Keep in mind, as pointed out to me by the grblpanel dev, it’s GRBL that doesn’t like three-digit tool numbers, not just this gcode sender. I believe there is a Carbide3D post-processor available for F360 which should know these things…
(Griff Carpenter) #17
The C3D post for Fusion was giving me arc errors in CM410.
I’m now using f360-easel.cps for my Fusion post. So far so good.
