Hardcore Aluminum milling on an S3
Chipbreakers :heart:
Test fit before final clean, debur, tig welding. Really happy with these but in hindsight I should have done the second setup a little different for better ball contouring accuracy. Decided to skip the fillet on the pocket.
Bolt tolerances and fitment are on point and should really help with the part strength in case an accident ever occurs. This will be a track car as well
I’m feeling it
Time to finish 2nd op on the set of “in stock” brackets. These take much more time for setup so I decided to have extra, they will fit all Recaro sliders and we do a bunch of Evos here. They are also great little pieces to show people cnc abilities.
Prepping the huge 3x4x12 blocks and finalizing this design, going to add some cooling/structural fins. The simulations will be very helpful to design desired strength as this intercooler could see as high as 70 psi of boost.
On a side note the landlord put in two separate 110 circuits and a 220 in the new cnc room. Kinda really stoked. Definitely need to either finish my enclosure or design a new one for a custom spec’d s3xl
I love your enthusiasm! It’s contagious.
@reidfo its excitement too, I’ve been fabricating for 17 years, my entire working life. To be able to express your craft in a different nature is primo.
You can make anything
Stay excited, stay young
Challenge possibilities
Speed comes with time
And share CAM settings.
:wink:
@neilferreri hoping to increase the previous max by 10-20%. But that’s a few sleepless nights away… actually might try a full DOC adaptive. This would be a hardware modification…
If you want to know setting for a stock z or stock plus beaver I can share those right now
I’m just curious what CAM operations you choose and what the settings are within those. I know my machine pretty well, but most of my knowledge comes from limited personal experience. It would be nice to gain from your experience by seeing a Fusion file.
Hey Vince, don’t you think it’s time for you to start a YouTube channel in your ”spare“ time? HaHa! something like NYC CNC?
In the meantime, keep up the good work.
Everyone loves shiny brackets
Edgy
Been a tough week, my business partner decided that he wasn’t going to work anymore and it came to a head finally. Im left with four heavy project cars that need my immediate attention and ive started a 19/5 schedule to try to compensate. Nineteen hours in the shop, five hours sleeping and repeat lol.
I know that’s oversharing but that’s the extent of my free time haha. Just trying to make the best out of the situation.
Future is looking bright and I can’t wait to share the details of my next project! Maybe just maybe I’ll try the video thing. The more youtube I watch the more I realize there isn’t that much good content for cnc router guys n gals
Ok, you got me…what is it?
Haha, auto nag…
@Griff This is a 20mm dual linear bearing bolt on upgrade for the X axis sir. I could sit and write a huge long winded post but ide rather just show you guys results.
200ipm or bust?
A few people much smarter than I like it so that gives me hope!
Looking good! I did this to my X axis top and bottom.
You have some cool projects going, Shapeoko and car related. I enjoy checking out the progress of both.
fiero1 Ray you need to make a thread on your upgrades. I like the new Shapeoko 3 slider. That picture above has my head spinning with spending money.
@TK-422 These upgrades aren’t too expensive if you do the work. Linear rails are cheap, mine were $56 for two assemblies shipped. Use your machine to make its own parts!
@fiero1 that’s awesome! Using 8 bearings total lol, love it. Thank you for the kind words, love being able to learn machining and integrate it so easily!
Wild setups, creative design, wall finish on certain parts contoured for O ring compliant sealing, 100% oem fitment and compatibility, tig welding goodness.
#makeeverything
AEM dash display module because who needs to sleep right? Going to fine tune angle and bracket it then black microsuede flocking for OEM look!
Your hardcore milling has definitely inspired me. I haven’t even completed my enclosure for my CNC yet but making the front control panel I ran into a problem with small text.
So I decided to make aluminum inlay buttons for each switch. I stopped by my local metal supply and bought some scrap aluminum for $12.
I then worked this out for the thin bars on the far left of the picture above.
I plan on cutting it out with 2.4mm and 1.2mm endmills. I cut the speed down to 350mm cut and 200mm depth per minute.
It worked (Kinda) I broke a couple end mills (1.2 and 1.4mm). By the time I got to the 1.6mm I had slowed it down to 50mm /m, that cut great but took 6 hours for the cleaning pass to 1mm deep. Somehow my XY were slightly off so the letters look a little wonky. I ordered some 1/8" brass to try again on Sunday.
/end hijack
