That tiny cutter below is a 30mm bottom bit…
Bet you can cut some canyons with that bad boy…
- SHAKING VIOLENTLY*
“Seeeems toooo be wwwwworking ffffine!”
If nothing else, this should point out where you need to add more rigidity to the system.
Guessing cut a 50mm profile?
