Anyone have suggestions on why this might be happening? I have a 15"x15" 3d relief that I am cutting. I set it to run last night and it quit halfway through the job. Quit like it was finished and returned the spindle to the rear left spot (like it does when I finish any toolpath).
Is there any kind of buffer or memory limitation I could be running into? I’ve attached the toolpath. I have limit switches set up on my Shapeoko 3. I’m using EDIT: Carbide Motion(The version from January 11th 2017).
My simulation works fine the whole way through. Any ideas would be appreciated, this is a big job so I’d rather not try to figure it out by trial and error.
Related question: is there any way to fast forward into a toolpath? If I could pick up where I left off it’d be a heck of a lot easier to test what’s going on.
