I put /z 22 in grble in the midi and hit send thinking that would move z to 22 so I could measure for setup. Now when I click move .1" it moves around .2". What did I do and how do I fix it?
Thank you.
I suspect that you altered the setting for # of steps / mm for $102.
If you have a Shapeoko, try sending
$102=40
(also see: http://docs.carbide3d.com/software-faq/shapeoko-3-default-grbl-settings/ )
— if you have a Nomad (I think this is the same for a Classic or a Pro),
$102=200.000
If that doesn’t work, contact support@carbide3d.com
For the record, to manually move, first check to see if you’re in Imperial or Metric mode (G20 or G21) and then send for rapid (in metric):
G0 Z22
or at 10 inches / min.(in Imperial):
G1 Z0.86614173 F10
Thank you. That helped me find what I was looking for. And I have reset the grbl. So now to levelling the bed.
