Remove .zip from the file above and replace with .f3d. The sketch has the basic dimensions, what I’m looking for is how to design in the typical gently curved shape of a typical grip. Maybe a loft or do I need to do something in the Mesh space? My F360 skills are pretty limited.
I’d start with loft, as the forms look to be the same over the length of the grip. Loft is much easier to get a consistent form than mesh. I would only use mesh if the surface was not a consistent profile, such as if you were going to make handed grips (impressions for fingers and thumb)
Griff
(Well crap, my hypometric precursor device is blown…)
3
@enl_public thanks, I’ll dig in to that tutorial and see what I can come up with.
It’d be great if you, or someone, could apply a loft to the file I attached. All I’ve managed to come up with is pretty funky. Just enough to get me started.
@Griff Let me start by saying I have no idea what these look like in person. Based on pics, it looks like a constant shape (not sure if that makes sense…too tired to post). I wouldn’t bother with a loft. I’d just use a cut extrusion. Gimme a minute.
Griff
6
Ducked out of a family affair to take a look at your file. Thank you.
I’m going to print one. I think it is exactly what I was looking for, I’ll delve deeper in the a.m. and report back upon my understanding of how you did this.
Griff
7
you’ve got it neil.
the final geo is all preference/non critical.
the outside profile and the bolt holes are the main thing which it looks like hes got situated.
you can check GrabCAD for a ton of 1911 files readily available to compare/contrast to as well.
Fusion360 has some great tutorials and YouTube is always a great resource for some basic CAD info
Griff
10
Thanks. Checked grabcad, tons of stl files, not a single cad file for the officers 1911 grip. Also, tons of F360/tutorials but if you don’t know what your searching for I.e. plane on an edge (thank you @neilferreri) the huge number of tutorials can be daunting. Haha I watched a few hours worth prior to my initial post. Plus 10 s of hours over the past couple of years. I knew there had to be an easier way.
Griff
11
Ok, thanks again. I’ve muddled my way through your wonderfully easy solution and have managed to duplicate it on my own. Printing another prototype now.
One thing I can’t work out, you noticed I’m sure, the long edges of the grip are not parallel. This results in a rise in the edge front to rear on the side of the grip opposite the plane along path. Any way to fix that? I guess like a plane along path that is an average of the two? Hmmm I guess I could draw an angle at that average and use it?
Edit. Setting a plane along path to the average of the two worked pretty well. Adding a taper angle of 0.98 made it perfect.
Now I have a basic template, fully customizable. Just need to learn to decorate it.
Thanks again for pointing me in the right direction.
@Griff I see what you mean with the non-parallel sides. Here’s a loft version…there were some issues with your original sketch (maybe why you had so much trouble with it), so check it before you use this one. It’s good practice to fully constrain a sketch, so modifications don’t throw something off. There were a few points that looked coincident (in the same spot) but were actually a microscopic bit off. i fixed the stuff I needed to, but it may have thrown off a critical dimension. I don’t think it did, though. https://a360.co/2CutPDn
You can go to thingiverse, download an STL of a plain 1911 grip, and then customize as you wish…
Griff
16
True I suppose for some of us. Not me, I’ve had no luck modding stl files, too many triangles and too many errors following cleanup in meshmixer on top of too little experience on my part. I’d rather start with a clean drawing.
Griff
17
@neilferreri thanks much for the 2nd approach, much appreciated.
And the tips. Someday I’m going to buckle down and really learn Fusion.
Griff
18
Ok, I really like the loft technique! Never yet used it for a project.
I’m usually winging it. I have the benefit of teaching a bit of CAD to 7th and 8th graders. Most of what I learn is from trying to help with their designs.
Griff
20
Well, in that case, I’m happy I can hang in with the seventh graders!
