Ok guys I really need some help with this image. I can not get a bitmap trace or anything to come out right for this image. If anyone can do this with a different program or way please help me out. I have spent a few hours and still nothing. I have been using Inkscape but I can get it to pick it up.
Better original or source? Group name?
still needs better source i think
looks like it’s from
http://www.iach.knox.amedd.army.mil/SitePages/Home.aspx
http://www.tioh.hqda.pentagon.mil/Catalog/Heraldry.aspx?HeraldryId=8645&CategoryId=4836&grp=2&menu=Uniformed%20Services&from=search
Yea that’s the source, and can’t find any other source. Making some stuff for some Soldiers here at Ft.Knox and I just can get any trace off that image.
how soon do you need it?
Next couple of days if anyone can help
It’s just MEDDAC Fort Knox, that’s what they are saying
Best I could find
Simple enough image, easy enough to re-draw. Just remember that it’s a lot of regular / repeated geometry:
Hang on, I’ll have a full re-draw done in a little bit.
Man your so awesome! I spent a good 2 hours trying to get it right and never worked it out. Thanks a lot your a life saver
This is simply traced. it could use some clean up since the lines are not 100% but it’s the fastest I could do (3 minutes worth) And it’s pretty good from what I can see in CAD.
LOGOTrace.dxf (247.3 KB)
traced with IntelliG-Code.
If I had a higher resolution input image it would help a lot.
Done.
Imports fine:
Man it looks great thank you so much!
