Help with vCarving a sign
(nick) #21
Wow making progress I’d love to see this to a finished file I just don’t have the knowledge or experience to get it there…Thanks for working in it
(William Adams) #22
Almost there:
Unfortunately, failed to:
  • add additional geometry for the outer profile to allow V-carving the perimeter
  • remove the grey highlights from the white area of the bird
  • properly separate the white areas of the runway
Anyway, the basic principle is to:
  • calculate how wide an area one needs for V-carving to the desired depth
  • add an inset along that centerline
  • adjust both paths so that things are rounded off so as to eliminate peaks
(nick) #23
Would it be possible/ easier to cut the interior around the eagle and runways out completely with a straight bit?
(William Adams) #24
It would depend on the scale and size of the bit relative to the piece. Basically inlay options go this way:
  • straight bit, inlay with vertical sides
  • smallest detail limited by endmill diameter
  • any narrow feature must be at least endmill diameter+10%
  • V-carve with angled sides — through cut
  • all inlay pieces must be same thickness
  • detail limited to one’s workholding ability / options / patience
  • V-carve inlay with pockets
  • requires specialized software or careful toolpath planning
(William Adams) #25
But with a bit of patience, it works:
small_separated_two.c2d (1.4 MB)
WTB: V Carve Desktop or Pro
(nick) #26
Is there a way to stop it from cutting all the way through?
(William Adams) #27
Further adjust the paths, or use a tool which limits depths, or use a shallower angle tool, or a thicker material.
I figure I’ll just fill w/ powdered enamel and epoxy.
Anyway, finally found time to cut this w/ the right endmills:
Need to get a loupe from work and deburr the edges and then work out some way to infill the colours.
Jewellery details from the Nomad?
Nomad for gift shop owner?!
