How good is the Shapeoko 3 XXL for 3D reliefs?
(Andres M) #1
I recently got interested in buying a CNC router and the Shapeoko seems to be the best one at a reliable price. My question is, how good does the Shapeoko 3 XXL cut 3D reliefs?
I will add a picture for what I’m hoping to do:
I am comfortable with CAD/CAM software and creating the g code, but I just want to make sure the machine is capable of running the code with the proper tooling. I am also aware the machine must be correctly calibrated.
Any pics of actual projects you have done with the Shapeoko XL/XXL would be cool
(I feel like I’m going to regret waiting such a long time buying it lol)
(Dan Nelson) #2
From your picture I’m having a hard time seeing the scale of this, but if it fits in say a 31"x31" envelope and the Z depth isn’t beyond 3" it should be okay, the accuracy is definitely good enough. I made this little box and I’m pretty happy with the detail:
And this was almost 2 1/2" thick, but I machined it as a flip:
Biggest limitation I’ve had is in Z depth, but there are aftermarket Z sliders that can add to that depth (you will still be limited by the length of 1/4" diameter tools available).
Dan
(William Adams) #3
The machine will do whatever one asks of it — list of supported G-Codes here: http://docs.carbide3d.com/software-faq/grbl-g-code-definitions/ (pretty much anything one would expect a CAM program to output).
We do have a gallery: http://carbide3d.com/projects/ and there is a 3D project in it http://carbide3d.com/projects/007-bamboo-carving/ — there are more in the forums here (and my thanks to @DanoInTx for posting his lovely work) , and at least one recently posted to the Facebook group.
(Andres M) #4
Thank you gentleman for your input!
I should have one by the beginning of January :slight_smile:
(Stuart) #5
You won’t regret it!
I have done a few reliefs, the machine is excellent for it, I can’t find any photos other than this horse, which was the first relief I tried, and it came out pretty well. designed in Vectric Aspire, no sanding to finish, just a light coat of poly
edit
found another small one i did on a bit of scrap
(Andres M) #6
That’s awesome! Thanks for sharing.
(Joel Bernstein) #7
Any idea how much time those took?
(Stuart) #8
ah, apologies… From memory the horse took roughly 3 hours of tool time - roughing with 1/4 endmill then finish with 0.5mm tapered ball nose.
the moose was probably 1-2hrs, similar tool sequence but 1/8 EM for roughing
(Art Peters) #9
Stuart:
Would you be willing to share the files used to generate the moose?
I am still early in my CNC journey and have become somewhat proficient
at running the machine, but the creation side lags considerably.
