How to define a roundover bit in Carbide Create
(Don Sieburg) #1
How can I define a roundover bit for edge finishing in Carbide Create
(ray) #2
I don’t have create installed, I use v carve but generally these programs are looking for a right side profile of your bit.
(William Adams) #3
If I understand what you’re describing correctly, I believe that is described in:
(David McMillan) #4
You mean something like this, correct?
(William Adams) #5
Do not use endmills w/ bearings.
That’s what routers and router tables are for.
(Don Sieburg) #6
Yes, but with the bearings removed, Is this possible?
Don
(William Adams) #7
With the bearing removed you’d need to work up an appropriate offset toolpath and feeds and speeds, prob. through testing — way easier to make and use a router table.
(Don Sieburg) #8
OK… I have 50 2.5" x 10" name panels to make.
I was trying to figure a way around using the table router but you’re right, it would likely take longer by the time I messed with all the settings and tool changes.
Thanks as always for the good advice!
Do
