Asdueitt
(Andy Dueitt)
April 15, 2018, 6:23pm
1
My wife and I use our shapeoko to cut our wood decor, I can’t merge these together without it cutting initials out. I need the circle to not cut out all the way around
WillAdams
(William Adams (Carbide 3D))
April 15, 2018, 6:49pm
2
Use Boolean Operations for this:
http://docs.carbide3d.com/assembly/carbidecreate/video-tutorials/#boolean-operations
c.f.,
Learn about the Shapeoko CNC Routers. They're fast, accurate, and reliable so you can make amazing projects to keep, give as gifts, or sell.
and this tutorial should cover some of the concepts:
I’ve been using a different hobby cnc machine with it’s own software for a number of years. The attached picture is an example of a plaque that I create with this software and machine.
I am trying to decide between purchasing a Shapeoko XXL or a X-Carve 1000x1000. I’ve gone through all the pros and cons of each machine. I’ve done a ton of reading on both machines forums. The “usability” of the base software that comes with each machine will play a part in my decision.
I’ve used both Carbid…
If you get stuck, send in your drawing and a note on your difficulty to support@carbide3d.com and we’ll do our best to help you out.
system
(system)
Closed
May 15, 2018, 6:49pm
3
