I imported a picture in carbide create
And I looked at the example with the Star Wars coasters and my art was an svg alien and it only shows up as nodes? So I cannot create a tool path? Not like the Star Wars example can someone tell me what I’m doing wrong?
Possible problems with SVG files:
  • embedded pixel image — these won’t import
  • unclosed polylines may lose beginning or ending segment
If you’ll post the image or a link to it, we’ll do our best to look into it.
image2vectorhere it is…
The problem is the paths are unclosed — this is indicated by their being magenta.
Select each object in turn and choose the Design | Edit Mode | Join option to close them.
https://www.shapeoko.com/wiki/index.php/Carbide_Create_Basics#Joining_Paths
alien.zip (460.2 KB)
ok, they look normal black now …the lines at least, now how did you figure that it was that way, I’m not that experienced in it yet… and i was able to use it…
How did you change that and what do i need to do with it in the future if i run into that?
I believe the magenta lines indicating open are covered at: Getting Started with Carbide Create
As I noted:
Shapeoko CNC Router, Rigid, Accurate, Reliable, and Affordable
Another thing now that i have it built, how are we suppose to secure the wood to the board if there are no holes? I just thought of that lol …
You can use double-sided tape, blue painter’s tape and cyanoacrylate glue, or drill holes yourself:
or mount T-track: https://shop.carbide3d.com/collections/tools/products/t-track-table
Or work up some sort of vice or other holding system: https://www.shapeoko.com/wiki/index.php/Workholding
