Hello all, I have an .svg file exported from Illustrator. When i open in Carbide Create the file has most of the data but is missing all of the straight lines. Any ideas on why or how to fix this issue?
Thanks
Thanks
Carbide Create doesn’t do well importing open paths — you can add additional nodes to them, or expand the strokes into closed paths.
Similarly, all type needs to be converted into paths since text won’t import.
